HEY. I have a question about using VDJ's smart crates in my productions. I have these specific goals in mind:
1) create folders separated by KEY
2) rename each audio file with the KEY prefixed
3) Separate each audio file by KEY and place them in their respective folders
i figured that VDJ has these capabilities that (except the renaming part) I can utilize these features in my productions.
can someone please give me some input. thanks in advance.
Posted Thu 27 Oct 16 @ 2:01 am
Try the my library install
Posted Thu 27 Oct 16 @ 3:20 am
As for 2, why do you need to when you can show key as a field,
The accord pad page may be of some use to you.
https://virtualdj.com/plugins/?addonid=80426
Posted Thu 27 Oct 16 @ 6:58 am
