How do i get my Behringer CMD studio 4a to work on virtual DJ? I've gone through all the steps that it has told me to do i think from what all I've done and need to get it working by Friday is there anyone that can help me out?
Posted Thu 20 Oct 16 @ 12:18 am
Did you look here?
Posted Thu 20 Oct 16 @ 12:23 am
Yeah i went that clicked on the setup and on the link for behringer as well and it downloaded the zip drive files but nothing else downloaded after that. Is there something else that i have to do? Do I need a Plus Behringer CMD Studio 4a Controller License as well as virtual dj license?
Posted Thu 20 Oct 16 @ 12:26 am
You should not need another license, as a subscriber you should be able to use any controller. So what's not working?
Posted Thu 20 Oct 16 @ 12:33 am
Maybe I'm doing something wrong then it's hooked up and when I try to use it nothing happens i'm not sure what i need to do to get it to work. It used to work a while ago with the system that was at the club i was working at and now i can't get it connect to virtual on my computer now and idk what else i need to do to get it working now.
Posted Thu 20 Oct 16 @ 12:37 am
What computer, and OS are you using? Does your computer see the controller?
Posted Thu 20 Oct 16 @ 12:41 am
Toshiba windows 8 and yes it does see it. Is there something that i need to download in order for it to work.
Posted Thu 20 Oct 16 @ 12:43 am
So when you open VDJ, it doesn't ask you if you want to use the Behringer as the sound card?
Posted Thu 20 Oct 16 @ 12:46 am
No
Posted Thu 20 Oct 16 @ 12:48 am
Check you PM.
Posted Thu 20 Oct 16 @ 12:54 am
- Do you properly see the unit in the Device Manager , without any yellow triangles ?
- Did you receive any error messages when you installed the drivers ?
- Does this application see the unit on the right side https://virtualdj.com/download/miditrace.exe ?
- Delete (backup) your settings.xml file from Documents/VirtualDJ folder and start VirtualDJ. If no Detection window appears , then definitely something is wrong with the drivers installation.
BTW, not sure what is your Operating system, but keep in mind that as per Behringer (see the Readme.txt file inside the drivers zip file) :
Supported systems: Windows XP, Vista, 7 and 8
Posted Thu 20 Oct 16 @ 8:07 am
