The red cross that appears through tracks that have already been played during your set (previously) is not coming up in some windows. For example, the history. In the image below, NO SCRUBS is the same track (same filepath) although it appears as played in the playlist (right) but not in the history (left)
Posted Wed 19 Oct 16 @ 12:30 am
You need to check the track has been played long enough (per your history setting) and that the deck fader is far enough up to register it.
Posted Wed 19 Oct 16 @ 8:26 am
History files will not update while you are looking at them, switch between 2 and it will update
Posted Wed 19 Oct 16 @ 8:52 am
