Hey guys I have a denon mc8000 and im trying to map fx 1 and fx2 buttons on mixer but lets say I map button fx2 to activate loop out it activates loop out on all decks dont know why if each chanel on the mixer has its own fx buttons please help thank you
Posted Sun 16 Oct 16 @ 3:47 pm
Im using vdj8.2 latest update
If you map the FX1 button as .. loop, then all the FX buttons will do the same action on the triggered deck. Its like you have 4 x PLAY buttons, mapped as .. play, and yes all of them will perform the same action, play the deck that its called from.
If for some reason you need to have the FX1 buttons to behave differently depending on the calling deck, you need something like ..
action_deck 1 ? dothis : action_deck 2 ? dotheother : action_deck 3 ? dosomethingelse : doadifferenthing
Posted Sun 16 Oct 16 @ 4:58 pm
thank you I will try that
Posted Wed 19 Oct 16 @ 9:42 pm
also I have one more question on the denon mc8000 if you press roll button it goes into roll mode, if you press roll button again changes color and it goes into saved loop mode, how can I map it to do this press roll button go into roll mode, press it againg and I want to go to 1/4 loop, 1/8 loop, 4 loop, different loop length in each pad and if I press Shift and roll go to saved loop mode please reply thank you,
Posted Wed 19 Oct 16 @ 9:54 pm
Does it? show me your mapping because I don't think it's default
Posted Wed 19 Oct 16 @ 10:17 pm
You cant map the SHIFT+ROLL mode button to trigger a different page. Only the first and the last Pad modes offer 3 modes. This is more or less a Hardware limitation.
So, if you need to load a different Pads page (e.g. the Loop one), you need to use one of the 10 pre-defined ones and change the Pad page name of the action pad_page 'Name' assigned to one of them.
Posted Wed 19 Oct 16 @ 10:50 pm
