I'm new to this DJ thing ... This is my first mixer VDJ 8. I'm trying to figure out how to connect my phone and other peoples phone to my computer so I can play playlists. I connect it with USB but I can'tfind it onthe screen. I have connected it into the mic input but there I have no mixer controls. Help ... I'm a beginner and I know it , but I will learn. Thx
Posted Fri 14 Oct 16 @ 12:30 am
Please do not hijack other members thread, and stay on topic, thank you. You are welcome to start your own thread.
Posted Sun 16 Oct 16 @ 2:52 am
This thread is about this posters issue. None of your post addressed his issue, so I have leveled them all up. It is like you are just ignoring his issue, in favor of yours. Just because it says "basic help" does not mean you can post any basic question here. Please start your own thread, and they will treat your thread with the same respect, as this guy deserves.
To the OP, If you are trying to use your phone with VDJ, it has to see it as a hard drive or storage device. I don't know what kind of phone you have so can't give you specifics. If you are going through your mic channel, then your mic gain and master gain should allow the sound to come through, provided you are using the right cable, and the channel is set to line.
Posted Sun 16 Oct 16 @ 8:16 pm
my virtual dj is not connecting with my iTunes...its not syncing....please help
Posted Sun 16 Oct 16 @ 9:08 pm
martex70, please read the post JUST above yours. Your issue has nothing to do with the topic of this thread. Please look for a thread with the same topic, or start your own thread. What you are doing is hijacking this thread, thank you.
Posted Mon 17 Oct 16 @ 6:53 pm
