Is there a feature list from VDJ 7 that is Not available in VDJ 8?
I see now on the forum that Netsearch no longer works in V8, is this going to be fixed?
I use these pluins in V7, do they still work in VDJ 8 or do they have replacements for them that behave in the same way?
1.Text2D.
2.SBDJ ScrollText.
3.SlideShow.
4.RandomVideoTransitions.
5.ClipBank & Random for Audio.
6.ShowLogo.
1.Text2D.
2.SBDJ ScrollText.
3.SlideShow.
6.ShowLogo.
Posted Thu 06 Oct 16 @ 10:52 pm
3.SlideShow.
6.ShowLogo.
3.SlideShow.
6.ShowLogo.
You can download Ver 8 onto your machine, they both can be on the same machine to compare. They are listed in the effects section. There are plugins available in the software, and in the plug in section to do what you need to do. You can use the video sampler to replace the clip bank. I have deleted the plug ins that do not work in 8. There are videos available to show most if not all of the new features.
Posted Thu 06 Oct 16 @ 11:30 pm
Thanks for the reply, noticed the Text2D and SBDJ ScrollText was not on your list, I use these weekly in V7 and is important to me for venues and new gig promo.
Anything available in V8 for this feature?...
Netsearch has been good to me when something I don't have is requested, and it helps me stay on top with guest, is this going to be fixed in V8?
Thank You...
Thank You...
Posted Fri 07 Oct 16 @ 12:21 am
i think vdj 7 is NOT as useful as vdj 8.Vdj 8 is so user friendly
Posted Fri 07 Oct 16 @ 9:04 am
Please download Version 8 and try for yourself. As stated, you will see all of the effects available. Everything that you need is there, but you have to try it. You are not the only one that needs these things, and version 8 has worked great for me.
There is a thread about content unlimited and Netsearch, here so let's not start another one.
Posted Fri 07 Oct 16 @ 10:15 am
The net is great for sharing information but read the manual, that's why it was written.
https://virtualdj.com/manuals/virtualdj8/appendix/nativeeffects.html
https://virtualdj.com/plugins/?category=effects
Posted Fri 07 Oct 16 @ 4:06 pm
Hi,
the VDJ8, has all the features you listed above, and more, once you tested you are not gonna a stop to use it,
regards,
GK
regards,
GK
Posted Fri 07 Oct 16 @ 4:58 pm
