Just upgraded v8.2b3420 and now my audio is all distorted like it would be back when we had the performance slider and it was out of whack. Is this a known issue with a fix or am I just lucky?
3GHz Win7 machine with 8G RAM
Screenshot shows sound card and setup, which is all correct and has worked fine till now.
Posted Mon 03 Oct 16 @ 8:32 pm
Update:
Restarting the PC seems to have fixed the issue. This is the first update that required a system restart and I'm on early release updates.
Posted Mon 03 Oct 16 @ 8:54 pm
2 ms latency is quite low
It would be easy for any background operation to interfere with that
Posted Tue 04 Oct 16 @ 5:13 am
