Hi everybody. I've Been using a pioneer wego for The Last 2 years And Now i would like To buy something more professional. Any suggestions? Thank forse your help.
Posted Thu 15 Sep 16 @ 5:50 pm
Traktor Kontrol S2 MK2 Cue Buttons don't light up in VirtualDJ Pro, they do work... any suggestions?
Posted Thu 15 Sep 16 @ 6:01 pm
@silverfox4562:
Please open a new topic for that issue; or would you search in this topic if you got problems with the Traktor Kontrol S2?
Posted Thu 15 Sep 16 @ 6:12 pm
If you like Pioneer controllers, you can't go wrong with an SX, SX2 or even an older S1. The SZ is their top of the line but you'll pay close to 2 grand for it new. The others, you can find really good deals on.
Posted Thu 15 Sep 16 @ 6:30 pm
Hello valeriosereni ,
It all depends on your budget and the money you're willing to spend.
I've been using Hercules RMX2 the past three years.
It has excellent built quality, brushed aluminum and steel, it's portable and has a convenient size, the same dimensions of a Laptop 15.6, so it's easy to carry and place in the venue that you're playing in. It has a great sound card built in with a sample rate 24bit/96kHz. The products of Hercules are built to last. It has RCAs and XLR outputs, completely compatible with Virtual DJ, many DJs use this product without any issues.
In it's price range it's considered one of the best.
I've been very satisfied with it so far !!!
I think you should check it out ...!
Posted Thu 15 Sep 16 @ 11:02 pm
Native-Instrument sent me an email. The mic works fine with the Traktor Kontrol S2 MK2.
Thank you.
Thank you.
Posted Tue 20 Sep 16 @ 7:26 pm
