Is it possible to set seperate effects on a sample slot? You can create groups and set the volume for each group, but can you also set efffects for a specific sample slot?
Posted Fri 09 Sep 16 @ 1:31 am
no
Posted Fri 09 Sep 16 @ 11:42 am
samples can be played through a deck though, wonder if samples slots can be assigned to different decks...
Posted Fri 09 Sep 16 @ 7:48 pm
Unfortunately the sampler only has one output.
Posted Fri 09 Sep 16 @ 9:13 pm
aaah feature request :-) For me personally if that was possible I'd remapp my NI-F1 to VDJ to act like a sampler pad, with volume and effects :-) I hope there is some other people who'd like that feature as well..
Posted Sat 10 Sep 16 @ 5:46 am
Well there's me for a start! I'm often dropping heavy hints around here that the so called sampler has barely any features that actual samplers have.
Individual outputs is one such feature.
How long ago is it that Atomix added the ability to use 99 decks? This is going to waste. Let's make use of those 99 channels for something.
Posted Sat 10 Sep 16 @ 7:57 am
99 oh, I didn't know that. Indeed if a sample group or slot can be assigned to an individual deck (including effect) that would be it :-) and there are 99... I could even hook up both of my F1's and have a blast. I always need Traktor to pull that off now (8 channel sampler with volume/effect per channel)
Posted Sat 17 Sep 16 @ 10:42 pm
