I have a primary laptop and a backup laptop, both are installed with virtual dj 8, i have logged into both of them with my VDJ account. I know that i am only allowed to run one at a time. My question is, what if my laptop freezes or hangs with virtual dj still connected and running and music still playing, then i connect my second laptop and start playing a song before the hanging laptop's song comes to an end.
What would happen in this instance, given that the period of both laptops logged in is under 5 minutes?
Your help is appreciated.
Posted Fri 02 Sep 16 @ 6:27 pm
That's all ok, nothing to worry about.
Posted Fri 02 Sep 16 @ 7:15 pm
Two computers running at the same time on your Virtual DJ Pro License should be OK.
I quote A Man And His Music from a recent post:
"The license is good for life, with 2 machines at the same time. If you sign into a third computer, it will log you out of one of the others. You can put it on as many computers as you want, but you can only be logged into 2 at a time. If you want to use more then 2 machines at the same time, you will indeed have to purchase more licensing."
Posted Fri 02 Sep 16 @ 7:49 pm
