am using behringer bcd3000 and i get audio sound drops (like ive pressed pause) for a few seconds and then after it continues to play, this happens on every song and this wasnt the case in the previous versions.
Am loosing business because of that PLEASE HELP!!!
Posted Fri 26 Aug 16 @ 8:44 am
How are you losing business, with a home version, that is only supposed to be used at home? What version of the software bare you talking about?
Posted Fri 26 Aug 16 @ 9:05 am
Am using virtual dj 8.2 and am not only using it at home
Posted Fri 26 Aug 16 @ 9:10 am
Using a home version for profit, violates the EULA.
Posted Fri 26 Aug 16 @ 9:13 am
ok
Posted Fri 26 Aug 16 @ 9:18 am
You are using 8.2, which build? If you go back to the previous build, do you still have the same problem.
Posted Fri 26 Aug 16 @ 9:20 am
No I dont
Posted Fri 26 Aug 16 @ 9:30 am
