I cannot scratch on the left Jogwheel of my SX2. I have done the whole shift/slip thing and when I try to touch the platter, the music stops. When I take my hand off of it, the music plays. I bought this controller today brand new.
I don't have this issue on the right. It works fine. Please help.
Posted Thu 18 Aug 16 @ 11:38 pm
Posted Thu 18 Aug 16 @ 11:39 pm
There are a couple of things that you can check one is what are your settings
Posted Fri 19 Aug 16 @ 5:38 am
I did both. Neither worked. Please help.
Posted Fri 19 Aug 16 @ 5:56 am
Let me look a get back with you
Posted Fri 19 Aug 16 @ 6:22 am
Is the slip vinyl button pushed on the deck
Posted Fri 19 Aug 16 @ 6:24 am
If the deck is not playing and you move the jog, does the track waveform moves ?
Posted Fri 19 Aug 16 @ 7:31 am
1st try the SX-2 default optional if work you may have unmapped your Jogwheel on that side.
Posted Fri 19 Aug 16 @ 1:47 pm
Waveform does not move. It is as if they are actual Vinyl. When I put my hand on the platter, the music stops and freezes. The song only continues playing when I remove my hand. If I put one finger on it, no sound at all.
Posted Fri 19 Aug 16 @ 3:48 pm
