Hi Guys,
Super simple question that I've searched for but couldn't find.
I will need to plug my controller into a mixer just to use as the connection through to the amp (so I won't be using the mixer to control anything).
How do I configure the Audio settings in VDJ?
Thanks!
John
Thanks!
John
Posted Thu 28 Jul 16 @ 4:53 pm
You don't change anything.
Just plug your controller in a channel on the mixer, turn up the mixer volume and play......
Posted Thu 28 Jul 16 @ 4:58 pm
No changes needed.
Posted Thu 28 Jul 16 @ 4:59 pm
Cheers guys!
This is all building up to my first real "gig" (work summer party) so I'm planning out the eventualities of if I'm forced to map onto CDJ2000 Nexus or (fingers crossed) use my existing set up and just plug in and go.
Appreciate the help.
John
John
Posted Thu 28 Jul 16 @ 5:04 pm
Considering its your first real gig, use what your most comfortable on.......
Posted Thu 28 Jul 16 @ 5:06 pm
That's what I would hope but here's the back story: https://virtualdj.com/forums/211351/General_Discussion/Worth_the_Risk__.html
Guy at work is making it super hard when all I need to do is plug into the mixer :(
Posted Thu 28 Jul 16 @ 7:23 pm
Then like I said in that thread, you should pass until you are familiar and comfortable with industry standard gear. I see this all the time at my club.
Its kind of a problem. I understand gear cost money and not everybody can ran out and buy top notch gear but you should either partner up with someone or rent some.
Where I work if you can't use our gear (turntables, VDJ's and sometimes an SZ) then you can't play.
They'll more gigs in future.
Posted Thu 28 Jul 16 @ 7:43 pm
