I have the xdj-r1 and almost every time i want to scratch it would freeze up my vdj or freeze the controller it self . has anyone had this problem? and can it be fixed ???IVE TRIED CHANGING LAPTOPS IVE UPDATED ALL SOFTWARE.
Posted Tue 12 Jul 16 @ 8:35 pm
I use the xdj r1 and have no problems.
My laptop is low spec. and I can scratch ok.
Maybe I can help.
I remember having a lot of trouble setting it up for VDJ.`
Have you upgraded the xdj r1 firmware?
If you have not already downloaded the latest Pioneer sound card driver it might help.
http://www.pioneerdj.com/en/product/all-in-one-system/xdj-r1/black/support/#info
What are the specs of your laptop?
The xdj r1 works very well with vdj8.
Better than Rekordbox!
The main problem I had was understanding what vdj8 was doing since at that time there was no specific manual.
I suppose this is still the case.
I spent a lot of time looking at the mappings trying to understand their function.
Note:
I did have a problem with a DJ who is appearing at Creamfields later this year who was using my equipment for a set. She could not use her flash drives and Rekordbox since the xdj r1 functions in a different manner to the Pioneer cd-j's so she used vdj8!
She was ok!
No bad comments.
She just said "we got the job done".
Maybe I can help.
Note:
She was ok!
No bad comments.
Posted Tue 12 Jul 16 @ 8:40 pm
there is a strong chance that the Jogwheels are incorrectly mapped in some custom mapping.
You can try ..
- to select the "factory default" mapping file from VirtualDJ Settings-->Controllers tab
- Remove (backup) any Pioneer-XDJ-R1 mapping files from /Documents/VirtualDJ/Mappers folder and restart VirtualDJ.
- Remove the settings.xml from /Documents/VirtualDJ folder
You can try ..
Posted Tue 12 Jul 16 @ 8:41 pm
When was the last time you checked ?
https://virtualdj.com/documents/Pioneer%20XDJ-R1%20-%20VirtualDJ%208%20Operation%20Guide.pdf
Posted Tue 12 Jul 16 @ 9:07 pm
A long time ago DJDad..maybe 6 months or more.
I mentioned it in this forum at the time.
Thanks for the link!
+1 that made me happy!
Posted Tue 12 Jul 16 @ 9:23 pm
