Firstly what are the differences between 8 and 8.2?
If I'm not too keen on 8.2 what do I have to do to go back to ver 8?
As 8.2 has been out for a little while now is it as fully stable as 8? if not what should I look out for?
Posted Thu 07 Jul 16 @ 9:31 am
Quote :
NEW: VirtualDJ 8.1 !
this new version is mostly focused on stability
and is a strongly recommended update.
- overall improved stability
- new Shazam integration
- new GeniusDJ folder
- new CloudList with collaborative listso
NEW VERSION 8.2
Atomix Productions is proud to announce a new version of its flagship software VirtualDJ, which brings many important improvements and new features:
In an era where DJ hardware is moving more and more toward a better synergy with DJ software, we redesigned VirtualDJ to be more controller-centric.
As such, the new pad section will fit right at home on most modern controllers, but at the same time brings a versatility and easiness that is the trademark of VirtualDJ.
The audio engine has been improved, and we managed to perfect even more our already top-of-the-line BPM analysis algorithm.
And our acclaimed video engine also saw some significant performance boost with a smarter use of hardware acceleration.
The connected aspect has not been forgotten, with some brand new features like Ask.The.DJ
And of course, the overall stability has been maintained to rock-solid level, with the lowest crash ratio in the industry.
NEW VERSION 8.2
You can download previous versions here (2523 is the last build of version 8.0) : http://www.virtualdj.com/download/build.html
Version 8.2 is perfectly stable, otherways it wouldn't be on full release.
Posted Thu 07 Jul 16 @ 9:49 am
