Is Vdj going to develop post fader audio effects....the other companies have them.
Posted Tue 05 Jul 16 @ 6:31 am
Open settings, search for "fxProcessing" option and set it to "Post-Fader"
Posted Fri 18 Nov 16 @ 12:38 pm[ selected best answer by PhantomDeejay on Fri 18 Nov 16 @ 12:38 pm ]
Do you have examples of effects that you are missing?
Posted Tue 05 Jul 16 @ 7:57 am
I am not missing audio effects, I use echo or delay, I would like to make use of these same effects, but with them programmed to be post fader effects. Traktor and Serato have audio effects that are post fader effects.
Posted Tue 05 Jul 16 @ 5:02 pm
If you open up the full interface for echo, you will see that there is a 'mute' button which can mute the source while continuing the echo.
Also the echo will continue without source if you move the strength to 100%.
I think both allow for similar effects as what you would do with the fader?
Posted Tue 05 Jul 16 @ 5:16 pm
Not the same thing........ Plus it wont work when you close the crossfader all the way.
Posted Tue 05 Jul 16 @ 5:24 pm
insurgent is correct....I do currently use the method you have suggested, but its not the same. If one compares VDJ with serato or traktor post fader audio fx can be clearly heard
Posted Tue 05 Jul 16 @ 5:50 pm
It's baffled me why this hasn't been added by now as it has been requested by a lot of VDJ users. Me included!
Posted Tue 05 Jul 16 @ 11:13 pm
Can this be addressed VDJ staff?
Posted Mon 11 Jul 16 @ 8:56 am
Hi guys.
Have Atomix looked into this?
Posted Wed 16 Nov 16 @ 2:51 pm
Yes, post fade FX processing meanwhile made it into VDJ.
Posted Wed 16 Nov 16 @ 2:55 pm
For me this is what I've been waiting ages for.
This would give many standalone controller DJs the experience as if using CDJ and a DJM mixer. I feel this is the one true lacking feature of VDJ throughout the years.
Mel
Mel
Posted Fri 18 Nov 16 @ 12:18 pm
Post fader effects are possible now on VirtualDj 8.2
Selected as best answer Posted Fri 18 Nov 16 @ 12:38 pm
Thanks for that update Phantom.
Must admit, I missed that post when I first read the thread. I'll give a go tonight and see how it sounds.
Posted Fri 18 Nov 16 @ 5:27 pm
Oh my god! It works!
I never knew of this setting. I've been messing around with all sorts of plug-ins these past weeks.
Many thanks, @PhantomDeejay for the top-tip! I, somehow, also missed the initial post you made on this one.
Posted Tue 22 Nov 16 @ 7:34 am
Can someone explain how I could use this to crossfade into a song with a completely different BPM or genre. Like with Serato and a mixer.
Posted Sat 25 Mar 17 @ 11:53 pm
