Last gig on Saturday I noticed a noise coming out from my PA.
It depends on the CPU load on my main PC.
As soon as I load a song, going over 25% cpu load, the noise is gone.
The CPU in that PC is a I5-650 and the PSU is new.
Could it be some BIOS settings ?
Posted Mon 04 Jul 16 @ 2:43 pm
cpu throttling maybe/
Posted Mon 04 Jul 16 @ 2:51 pm
OK. Where do I control this ?
In performance settings CPU speed is set to 100% all of the time , if that's what u mean
Posted Mon 04 Jul 16 @ 2:56 pm
Most likely it's not the cpu throttling that causes this but the cpu fan throttling.
So try to see bios for cpu fan settings
Posted Mon 04 Jul 16 @ 3:23 pm
The CPU fan is set for maximum speed and not temp controlled.
Could it be just a "noisy" motherboard ?
Posted Mon 04 Jul 16 @ 3:41 pm
This is probably a stupid comment but xlr cables get rid of my noise problems?
Posted Mon 04 Jul 16 @ 10:33 pm
Not a stupid comment but my investigation has gone beyond that:
When connecting any controller, my HC4500 or MC6000 I can hear the cpu activity as "digital noise crackling" directly on the line out's from those controllers.
It's worse when cpu has low load and gone when cpu reach 25% or more (loading a song)
It might also has to do with SSD activity since loading a song does use the SSD's of course.
Fans and CPU has no throttling activated.
Connecting my controllers to my back-up PC, the noise is always gone.
Posted Tue 05 Jul 16 @ 8:28 am
Are you using the Denon Asio drivers as they are notorious for this. I used to notice the crackling got worse if the mains were disconnected. Since moving to the WDM drivers I have never had any further issues.
Not sure if it is a PC issue or just the drivers themselves.
Posted Tue 05 Jul 16 @ 8:32 am
As far as I remember I also tried with WASAPI , but will test again.
Posted Tue 05 Jul 16 @ 9:49 am
