Hi everyone, is there any way or a setting i am missing because my history never shows everything a play at an event it leaves out at least half of what i play an its done this for so long its just such a pain in the neck can any one shed any light i this
Posted Sun 12 Jun 16 @ 4:24 pm
go into your browser settings (in VDJ8) and see how long the time is for history delay. default should be 45 seconds
Posted Sun 12 Jun 16 @ 4:56 pm
yes i thought of that too, i even changed it to a lower time to play to do counted. even my library is not picking it up either, VDJ gods do you have any ideas here.
Posted Sun 12 Jun 16 @ 5:08 pm
let me look at my last SETS i did last night coz i think some songs are missing. i need to look into my playlist in my virtual dj folder and then ill look at my playlist SETS in the website
Posted Sun 12 Jun 16 @ 5:12 pm
everything is all there for me
Posted Sun 12 Jun 16 @ 5:23 pm
Make sure the deck faders are turned up far enough. If you run the faders below a certain point then the track won't be recorded as played.
Posted Sun 12 Jun 16 @ 6:28 pm
ok i dont know how i just did it but now in the history file "play time" is now showing in my history where it was not before and now im getting all my songs. yeah. i think it was maybe because i did a Recurse and poof its all showing up now, in military time but how cares ill take it
Posted Sun 12 Jun 16 @ 6:35 pm
i dont understand about the folders could you explain please
Posted Sun 12 Jun 16 @ 6:36 pm
Posted Sun 12 Jun 16 @ 7:37 pm
theres more history in that. i just deleted about 2 yrs of history, i always keep it clean
Posted Sun 12 Jun 16 @ 7:43 pm
Hi Guys and Gals. My qusstion is a small one. I recently began using VDJ8 and I notice I no longer have the recently added folder and the compatible songs folder that I have in VDJ7. Is there a way for me to turn these on in VDJ8?? Thanks for any and all help.
Posted Sun 12 Jun 16 @ 9:36 pm
it will be easier if you open up your own thread
Posted Mon 13 Jun 16 @ 4:44 am
i assume you were talking about the VDJ Folder that i was saying?
Posted Mon 13 Jun 16 @ 4:46 am
You can still create those ...
Recently Added : top 50 firstseen
Compatible Songs : bpmdiff<=4 and keydiff=0
Posted Mon 13 Jun 16 @ 4:48 am
hi guys getting back to my question, I set the play time to 15 seconds.
now i dont understand but i've lost all my play counts. is there anything i can do to get this info back
Posted Sun 17 Jul 16 @ 1:37 pm
I'm going to make this a new question
Posted Sun 17 Jul 16 @ 2:06 pm
have you deleted an XML file?
Posted Wed 27 Jul 16 @ 9:13 am
Hi everybody,my laptop fell and my hard disk is dead is there anyway to get my playlist back coz i spend so much time on these
Thx in advance and keep on mixing!
Posted Fri 12 Aug 16 @ 12:57 am
Not really, depends how dead it is and if you're willing to spend the money for a specialist.
Posted Fri 12 Aug 16 @ 1:04 am
Are you sure the HDD is dead? Not only is the HDD protected by the casing, but laptop drives should be shock resistant too.
Just because the laptop doesn't start, don't blame the HDD straight away. Take it out and try accessing it from another computer.
The most important thing though, dead HDD or not, is to KEEP BACKUPS OF YOUR FILES!
Posted Fri 12 Aug 16 @ 8:55 am
