It isn't very clear what the difference is between Virtual DJ LE and the Home Edition of Virtual DJ is.
Their website says that it doesn't have a full file browser, you cannot access full options and will display adverts. I have also heard that you cannot record your mixes. Can anyone elaborate and clarify these things because that would be a great help.
If you could also answer some of my questions that would also be great.
- Can you record Mixes
-Can you make playlists and have filter folders
-Can you set keys on your laptop keyboard to do custom commands
-Can you use a separate USB sound card
-When are Adverts Shown
-What other features are missing from Virtual DJ LE that you get in the Home Edition
If you could answer any of these questions that would be amazing.
Posted Fri 27 May 16 @ 8:42 pm
- Can you record Mixes Yes
-Can you make playlists and have filter folders Yes
-Can you set keys on your laptop keyboard to do custom commands Yes
-Can you use a separate USB sound card Not Sure
-When are Adverts Shown Don't Know
Posted Fri 27 May 16 @ 11:52 pm
Posted Sat 28 May 16 @ 7:01 am
