Hello all !
I got a quick question: I'm exporting wav files from FL studio with markers/cue points. Other programs (like Wavelab, Wavosaur, Gold Studio etc.) are reading these markers perfectly (both names and position/time). When i load them in VDJ it reads them but it puts them in wrong position (all at the first minute of the track).
Is there a way to correct this without manual editing the cue points?
Posted Sun 22 May 16 @ 7:07 am
In config, getcuesfromtags is set to..........
Posted Sun 22 May 16 @ 7:13 am
Wow! That was quick! It's set to: for new files
edit: I tested it with "always" and "no" but nothing changes :(
Posted Sun 22 May 16 @ 7:22 am
I would think that would be the correct option. Maybe someone smarter will be able to help you out.
Posted Sun 22 May 16 @ 7:51 am
If you saved the file earlier with the same name, you can try right-click and select reload tags to load the cue points from the file again.
Posted Sun 22 May 16 @ 8:06 am
So he would highlight all the tracks, right click, batch, and reload?
Posted Sun 22 May 16 @ 8:13 am
No luck either. I think it has something to do with the way VDJ reads the position. In database.xml it stores (and maybe tries to read) the position in seconds:miliseconds, but other programs read minutes:seconds:miliseconds
I'm no expert, i'm just saying maybe.
Posted Sun 22 May 16 @ 8:22 am
What you have to bear in mind is that FL Studio is a DAW, and those other progs you mentioned are audio editors.
None of them are DJ software.
If you'd found that Serato DJ, Traktor, Rekordbox DJ, DEX 3, MIXXX and Cross DJ all read them correctly, then that would have been a valid comparison.
What are the files anyway? Are they samples/loops, full tracks you've downloaded, or your own productions? I'm just wondering why you're using FL Studio.
Posted Sun 22 May 16 @ 9:46 am
Wav cue points were indeed read incorrectly. They will be read correctly (including name) in the next update.
(You will need to set getCuesFromTags to always, and batch->reload tags your existing files to update the cue points in virtualdj)
Posted Sun 22 May 16 @ 10:21 am
I know. I'm not comparing with any other dj software. I already chose to work with VDJ, because it's fully customizable and it reads/edits the cue points! I'm using FLS to produce my tracks and i want to perform live with a couple of singers, using VDJ. It would save me time and effort if i didn't have to edit cues for 30+ songs...
Those are great news!
Thank you guys for your prompt answers and help! :)
Posted Sun 22 May 16 @ 11:49 am
