Hello everybody,
Does anyone have the same problem ?
MacBook El Capitan Version 10.11.4
Virtual DJ Version 8.1 Release 2857.1116
Automix runs after 45min silence!
What happend? I Must Login in The Mac and See VirtualDJ is closed. This happend since a few Weeks Or months
The energie modus is "Never shut down"
Posted Thu 05 May 16 @ 9:03 am
Ok, i don´t found a solution, but i think it is a OS X Problem.
My Macbook would Log out after ca. 40min and shut down all programs.
Now i installed OS X 10.11.5 the newest update tonight, but i have the same problem...
Here you can see, the energie options are ok!
How or where can i change a option "never close virtualdj if one player runs"?
On the next photo you can see, my ftp program stop the log off and ask me bevor the program make a shut down
Posted Tue 17 May 16 @ 12:24 am
Problem found, but i have no solution!
Anyone here as MAC Specialist to solve this Problem?
Sorry guys, this isn´t a VDJ problem, but there are more people with the same problem...
Posted Thu 19 May 16 @ 11:34 pm
try in your terminal:
sudo pmset -a autopoweroffdelay 86400
this is one day
this is one day
Posted Fri 20 May 16 @ 7:08 am
but i don't think that it is the problem, because 14400 is 4 hours, not 45 minutes.
Posted Fri 20 May 16 @ 8:57 am
Yes i know... Its terrible! I
Posted Tue 07 Jun 16 @ 8:47 pm
OS X El Capitan reinstall is the solution.
Posted Thu 23 Jun 16 @ 5:50 am
