Guck mal bei Optionen MixerOrder, ob das was bringt.
Posted Fri 31 Jan 20 @ 1:29 pm
MCX8000 Firmware v2.2 Private Beta
Hi All,
We are preparing the next firmware release for MCX8000. Before we release publicly, we would like to test privately with a smaller group. This is a private beta (under NDA) so you will not able to discuss features within this build publicly.
If you are interested and agree with above, please download this NDA agreement 32. Once completed send signed copy to ouremail using MCX8000 BETA TEST as the email subject line and be sure to include your forum user name in the email body.
Thanks!
und
Engine Prime 1.4.0 Public Beta
New Features:
Sync Manager is a new feature in Engine Prime that provides seamless syncing of Crates, Playlists & Metadata between your Engine Prime library & Engine Prime Target devices.
To open Sync Manager, simply press the Sync Manager button in the bottom left-hand corner of Engine Prime.
Sync Manager - export music to removable drives and sync metadata back to Engine Prime from Engine Ready hardware
macOS 10.15 Catalina support
Apple Music app support
Crate, Playlist, third-party collection and folder icons are now located on the left side bar
Add Crate, Playlist, Playlist Folder icons are now located in the tree view of the collection panel
Device Panel moved to bottom of collection panel and can now display multiple devices open at once
Improvements:
Optimized Serato DJ collection import times
Fixed an issue where display could freeze when force removing active audio device
Fixed an issue where new Traktor performance data was not updated when re-imported
Fixed an issue where creating new crates/playlists/playlist folders would not highlight the correct crate/playlist/folder for renaming
Fixed an issue where tracks with a BPM value of 125.00 could not be doubled
Fixed an issue where album artwork could not be updated if the artwork was added to the track after first import
Fixed an issue where MCX8000 Compatibility status was not detected on third-party libraries
Fixed an issue where file type was not shown on first import of third-party libraries
Fixed an issue where BPM filter does not display all results
Fixed an issue where tooltips for underlying elements displayed incorrectly when search field selection box was open
Fixed an issue where USB drives would fail to eject
Fixed an issue where Engine Prime could be quarantined by antivirus software
Fixed an issue where loading an un-analyzed track could change the sort order
Fixed a crash that could occur on Serato DJ library import/update
Fixed an issue where tracks imported from Serato DJ could show a date added value of 01-01-1970
Fixed an issue where the Search box could lose focus while typing
Fixed an issue where the total time of a crate/playlist could show as 0 seconds on first import
Fixed keyboard shortcuts that were not working as expected
Added a warning message if the default ‘Music’ folder is unavailable
Fixed an issue where packing a playlist from within a playlist folder from one external drive to another would sometimes fail
Fixed an issue where export to MCX8000 would fail if the track(s) exist only on the destination drive
Fixed an issue where the scroll bar wouldn’t respond correctly during drag n drop to device panel
Other various stability enhancements and improvements
Known Issues
EULA window in 1.4.0 will still show an ‘update available’ option if the ‘Ignore version’ option was selected from the EULA window in the last officially released version of Engine Prime
Hi All,
Thanks!
und
New Features:
Improvements:
Known Issues
Posted Fri 31 Jan 20 @ 7:42 pm
Hallo,
ich habe einen MCX8000 und bin Anfänger. Die 4 Decks mit der Software Serato DJ zu nutzen funktioniert bereits.
Mein Windows 10 zeigt mir 3 Ausgabegeräte an wenn der MCX8000 angeschlossen ist.
Wie kann ich nun eine andere Soundquelle (z.B. Mediaplayer, Youtube App) auf Channel 3/4 ausgeben um z.B. die Lautstärke dieser Quelle per MCX8000 zu steuern?
Im Moment gibt der MCX8000 den Sound des Laptops immer über den Master aus, aber ich würde es gerne separat auf Channel 3 oder 4 steuern können.
Ich hoffe ich konnte mein Problem verständlich erklären und wäre für Hilfe und Tipps dankbar.
LG
Ho
LG
Ho
Posted Wed 05 Feb 20 @ 3:14 am
Externes Gerät, z.B. Handy und am Line Eingang anschliessen.
Posted Wed 05 Feb 20 @ 8:50 am
https://de.virtualdj.com/forums/233218/German_Forum/Denon_MCX8000_und_VDJ2020_Update_Problem__Controller_reagiert_nicht.html
Moin,
ich bekomme einen Controller nicht zum laufen:
Denon MCX8000 Neueste Firmware
MBP 10.13.6
VDJ Infinity Pro 2020 inclusive. neuestes Update
Unter Controller wird
2x Denon Display Left und
1x Denon Display Right angezeigt ! (siehe Foto 2),
dort müßte doch eigentlich einmal nur Denon MCX8000 stehen. Ist das ein Bug bei VDJ ? Hat dieses Problem noch jemand ?
Die Titel werden auf den Displays angezeigt aber die Controller Fader, Knöpfe etc reagieren nicht, keine Ton Ausgabe, Ton kommt nur über interne Lautsprecher am MBP.
Moin,
MBP 10.13.6
Posted Thu 06 Feb 20 @ 11:19 am
user21295435 wrote :
Hallo,
LG
Ho
LG
Ho
Aus dem Lappi per MiniKlinke in den externen Eingang am MCX
Posted Thu 06 Feb 20 @ 5:27 pm
Hat jemand in letzter Zeit Probleme mit ~Sound hängern~ gehabt in der Kombination: MCX8000 -> Windows 10 64 Bit -> Virtual DJ 2020 Build 5504 64 Bit.
Tritt sporadisch bei ASIO auf. Ton hängt für ca. 5 bis 8 Sekunden und läuft dann weiter.
Problem liegt wohl nicht am MCX8000 oder Virtual DJ sondern am Treiber und/oder am eingesetzen Laptop oder Einstellungen innerhalb der Systeme, leider gehen mir die Ideen aus was und wo ich noch etwas an den Einstellungen ändern könnte.
Die Leistungsfähigkeit der Hardware ist es nicht.
Vielen Dank für weitere Tips....
Posted Sat 07 Mar 20 @ 7:46 am
Lass doch mal LatencyMon laufen.
Starte deinen Laptop so, als wenn du auflegst,
allerdings ohne VDJ.
Lass LatencyMon ruhig länger laufen, bis zu1-2 Stunden.
Posted Sat 07 Mar 20 @ 8:11 am
Hallo,
ich hoffe, Ihr lacht euch nicht tot, aber ich habe zufällig diesen Stammtisch gesehen und stelle fest, das es mit dem Denon MCX8000 doch wohl Probleme gibt. Ich hab mir das Teil bestellt, wird am Montag geliefert.
Was muss ich tun, das der Controller Virtual DJ tauglich ist. Hab am Anfang was von einem Mapping gelesen.
Ist das noch relevant? Wäre für ein paar Tips sehr dankbar
Bin neu auf dem Gebiet des Arbeitens mit einem Controller. Mach zwar schon seit 43 Jahren Diskothek aber bei MP3- basierender Musik bin ich bisher immer nur mit dem Notebook klargekommen. Möchte mich aber weiterentwickeln.
Gruß Andreas
Gruß Andreas
Posted Sat 07 Mar 20 @ 6:00 pm
Schliess das Ding erstmal an und versuche Musik raus zu bekommen.
Dann schauen wir weiter.
Ich empfehle dir den Skin "The Thing".
Übersichtlich und funzt tadellos.
Posted Sat 07 Mar 20 @ 6:31 pm
Hallo mobilbude,
genau so werde ich es machen. Danke für den Hinweis zum Skin.
Gruß Andreas
Gruß Andreas
Posted Sat 07 Mar 20 @ 7:48 pm
Gerade Info bekommen
Release Notes Engine Prime Version 1.3.4 03/11/2020
New Features:
• macOS 10.15 Catalina support
• Apple Music app support
• Add Crate, Playlist, Playlist Folder icons are now located in the browser view of the collection panel
• Crate, Playlist, third-party collection and folder icons are now located on the left side bar
• Device Panel can now display multiple devices open at once
Fixes and Improvements:
• Optimized Serato DJ collection import times
• Fixed an issue where creating new crates/playlists/playlist folders would not highlight the correct crate/playlist/folder for renaming
• Fixed an issue where MCX8000 compatibility status was not detected on third-party libraries
• Fixed an issue where file type would not be shown on first import of third-party libraries
• Fixed an issue where BPM filter would not display all matched results
• Fixed an issue where the search box could lose focus while typing
• Fixed an issue where Engine Prime could freeze when force removing an active audio device
• Fixed an issue where new Traktor performance data was not collected when the Traktor library was re-imported to Engine Prime
• Fixed an issue where album artwork that was added to track after importing into Engine Prime would not be updated in the file
• Fixed an issue where tracks with a BPM value of 125.00 could not be doubled to 250.00
• Fixed an issue where tooltips for underlying elements would show incorrectly when the search field selection box was open
• Fixed an issue where USB drives would sometimes fail to eject
• Fixed an issue where Engine Prime could be quarantined by antivirus software
• Fixed an issue where loading an un-analyzed track could change the sort order
• Fixed a crash that could occur when loading tracks from read-only drives
• Fixed a crash that could occur on Serato library import/update
• Fixed an issue where tracks imported from Serato could show a date added value of 01-01-1970
• Fixed an issue where the total time of a crate/playlist could show as 0 seconds on first import
• Fixed keyboard shortcuts that were not working as expected
• Added a warning message if the default 'music' folder is unavailable
• Fixed an issue where packing a playlist from within a playlist folder from one external drive to another would sometimes fail
• Fixed an issue where exporting to MCX8000 would fail if the tracks existed only on the destination drive
• Fixed an issue where the scroll bar wouldn’t respond correctly during drag n drop to device panel
• Fixed an issue where some tool tips were not displaying correctly
• Other various stability enhancements & improvements
download:
https://www.denondj.com/downloads
New Features:
download:
Posted Wed 11 Mar 20 @ 7:49 pm
So, der MCX 8000 ist vor nun einer Woche angekommen, hab viel probiert, alles zum Laufen bekommen und am Sonnabend die erste Veranstaltung damit erledigt. Ein tolles Teil, ich bin sehr begeistert. Da ich auf einem Windows Rechner arbeite, musste ich ja auch nur den Windows- Treiber installieren. Eine Frage habe ich aber noch. Wie bekomme ich heraus, welche Firmware-Version auf dem Gerät installiert ist. Wäre schön, wenn mir da einer helfen kann.
Gruß Andreas
Gruß Andreas
Posted Mon 16 Mar 20 @ 8:56 am
Dann mal herzlichen Glückwunsch und alles ohne zu fragen.
Respekt.
Drück mal den View Button länger ( links neben Display )
Dann scoll mit Select Load ( rechts neben Display ) runter.
Da kannst du es sehen.
Oder lade dir die aktuelle Firmware runter.
Den Anweisungen folgen, entweder er macht ein Update, oder sagt dir, dass deine Firmware aktuell ist.
Respekt.
Posted Mon 16 Mar 20 @ 9:29 am
Hallo Mobilbude,
danke für die Info. Werd es heute abend mal ausprobieren.
Gruß Andreas
Gruß Andreas
Posted Wed 18 Mar 20 @ 1:46 pm
Mit der Gefahr, dass mich keiner versteht, poste ich trotzdem mein Anliegen.
Ich wollte gerne einen DJ-Controller haben und fing an mich zu informieren. Da ich diesen nur für privat daheim nutzen will, habe ich evtl. die Prioritäten anders gesetzt als ein Hobby- oder Profi-DJ.
Jedenfalls habe ich mich erstmal eingelesen und dabei festgestellt, dass es relevant ist mit welcher Software man arbeiten will und das die Geräte entsprechend damit "verknüpft" sind und damit ausgeliefert werden. Dabei stolperte ich über Serato, VirtualDJ, Traktor etc.
Ich habe mich da richtig käck gemacht eine Entscheidung zu treffen um den idealen Mix zu finden zwischen Software und Gerät. Da man z.B. liest, dass Traktor bei Techno-DJ's beliebt ist. Somit bin ich davon ausgegangen, dass je nach Software entsprechend Funktionen am Gerät bzw. für das Gerät verfügbar sind.
Ich probierte im Vorfeld VirtualDJ aus in dem ich den Laptop direkt an meine Surround-Anlage anschloss und hatte richtig Spaß dabei verschiedene Effekte etc. auszuprobieren.
Am Ende entschied ich mich eher geräte-lastig und kaufte mir den Denon MCX8000 mit Serato und Engine Prime.
Und jetzt frage ich mich ernsthaft wofür ich knapp 1000€ ausgegeben habe. Mag sein, dass ich keine Ahnung habe. Es macht ja auch mehr Spaß als einfach nur ne CD laufen zu lassen, aber ist das alles was man im Jahr 2020 bekommt?
Anders gesagt, wo ist den jetzt der Unterschied bzgl. Software? Bzw. wofür ist die Software eigentlich? Ich sag mal so, durch die USB-Ports kann ich auch einfach Sticks mit Tracks reinstecken und fertig. Und dann habe ich am Controller 3-4 Knöpfe an denen ich drehen und die abgespielte Musik etwas verändern kann. Aber ich habe keinerlei Effekte. Weder am Gerät noch in Serato.
Ist die die Software nur dafür da Lieder zu ordnen etc.? Wieso suchen dann so viele nach Mappings für Traktor? Was bringt denn Traktor einem Techno-DJ für Vorteile?
Ich glaube ich verstehe das Ganze irgendwie nicht. Dann hätte ich auch weiter mit VirtualDJ am Rechner arbeiten können und hätte viel Geld gespart. Ich meine, ich bin aktuell immer noch auf der Suche nach einer Funktion bei der ich die Länge Loops und die Position selbst anlegen kann. Und nicht automatisch oder nur über Halbieren oder Verdoppeln.
Sicher macht das Spaß damit aufzulegen, aber es könnte mit der Zeit langweilig werden. Ich denke ihr versteht was ich meine und könnt evtl. etwas Licht in die Sache bringen.
Frohe Ostern an alle!
Posted Sun 12 Apr 20 @ 4:47 pm
Ich versuche mal eine Antwort zu geben. Wenn du das nur für zu Hause willst, hast du schon mal viel Geld für Dein Hobby aus gegeben. Ist ja nicht schlimm, tun andere auch z. B. Fotografie. Du hast dir einen sehr gutes Gerät gekauft, dessen Umfang und Möglichkeiten du vielleicht nach ca einen halben Jahr voll nutzen kannst. Vorausgesetzt du beschäftigst dich damit sehr oft( Bedienungsanleitung und üben).
Was der DJ mit Traktor und Serato kann, geht mit Virtual DJ schon lange, ist so auch wenn du anderen Meinungen dazu finden wirst. Ich habe alle 3 Software in der Pro Version und probiere aus, wenn die anderen mal sogenanntes Neues bringen.
So wie du schreibst, würde ich dir empfehlen, wenn noch möglich, dann schicke das Gerät zurück und kaufe ein Anfänger Kontroler so bis 300 Euro. Das ist übrigens nicht abwertend gemeint. Weiter viel Spaß beim ausprobieren.
Posted Sun 12 Apr 20 @ 5:14 pm
Ich versuche auch mal dir ein bisschen zu erklären, wie was wo bei DJs läuft. :-)
Ich finde den MCX8000 vom Prinzip her genial und arbeite sehr gern mit ihm.
In Serato hast du vorallem die Möglichkeit Songs sauber abzuspielen, es ist Tatsache nur als Datenbank mit abspielfunktion gedacht. Du hast Effekte und kannst die Musik etwas verändern, den Songs eine persönliche Note geben, interessant wird es aber erst, wenn du schnelle Songwechsel hast und diese gut mixt.
Da gibt es bei YouTube genug Videos zu.
Traktor hat eine einzigartige Möglichkeit, du kannst Songs Stems in die einzelnen Spuren zerlegen und damit komplett neue Musik erschaffen.
Bei beiden Programmen geht es um die Kreativität des DJs.
Virtual DJ hat den Ansatz den Computer mehr als Computer zu nutzen, du kannst Musikvideos abspielen, die Mappings und Skins komplett für dich anpassen und viele Informationen in den MP3 Tags hinterlegen und abrufen.
VDJ ist eher auf den Nutzer ausgelegt, der seine Technik auf seine Arbeitsweise anpassen will.
Mein MCX ist komplett anders gemappt, als unter serato, so kann ich noch leichter mit arbeiten. Im Skin habe auch einiges geändert, so dass ich z.B. für meine Radiosendung immer alle relevanten Infos im Blick habe.
Und ansonsten kannst du das gleiche wie mit Serato und Traktor machen.
Für dich musst du jetzt entscheiden, was für ein DJ du bist, ich bin z.B. Hochzeitsdj und brauche z.B. Den Automix für die Tischuntermalung, sie Sidelist für Wünsche und nutze die Videofunktion für mein Logo. Ich muss in wenigen Sekunden 10-20 Songs im Kopfhörer anspielen können, wenn ich was bestimmtes suche, das geht unter Traktor nicht.
Es sind also vorallem deine Vorstellungen, wie du arbeiten möchtest, die über die Software entscheidet. Mit dem MCX hast du ein Riesen Werkzeug, mit dem du alles machen kannst, vielleicht wäre aber Tatsache der Prime 2 oder der noch kommende Prime Go für dich besser, da brauchst du gar keine Software. Das kannst aber nur du wissen :-)
Posted Mon 13 Apr 20 @ 12:36 pm
Die Hardware MCX dient im PC-Modus als Fernbedienung und Soundkarte von VDJ das meiste passiert und regelt die Software im PC-Modus hier ist die Software entscheidend.
Ich habe bis heute Serato nicht mal installiert da ich mit VDJ 100% zufrieden bin und mir alles so anpassen kann wie ich es haben möchte.
Im Engine Modus (Notfall Modus) ist man sehr eingeschränkt nur 2 Decks wenig Effekte keine Vorhörfunktion die Lieder müssen vorher mit Engine Prime vorbereitet werden usw. ist eher als Backup Modus zusehen wenn der Computer ausfällt oder so. Für manche Leute reicht das aber völlig aus
Press and hold the SHIFT button and then move the platter
While editing a loop, move the platter to adjust the Loop In or Loop Out point.
Posted Mon 13 Apr 20 @ 2:04 pm
Erstmal danke für die Antworten und Hilfestellungen.
Mittlerweile sind ein paar Wochen vergangen und ich habe mich ein wenig mit dem Gerät befasst.
Es bleibt dabei, ich bin halt kein DJ und mache das nur am Wochenende für mich im Wohnzimmer. Ich habe mittlerweile auch Licht dazugekauft etc. und alle sind begeistert, die sich meine Videos anschauen. Das freut mich natürlich, da ich ja selber weiß, dass ich viele technische Fehler mache und auch die Übergänge verbocke. Ist halt viel Arbeit und Übung. Aber wenn alle begeistert sind, bin ich ja auf dem richtigen Weg.
Zum Gerät selbst, ich habe halt keine Vergleichsmöglichkeiten, da es mein erstes Gerät ist, aber eins steht fest, bis jetzt möchte ich es auf keinen Fall mit etwas anderem tauschen wollen. Das ist ein super Spielzeug für mich. Sicher etwas für einen Profi, aber ich möchte auch all die ganzen Möglichkeiten haben und nutzen. Das möchte ich nicht mehr missen.
Es sind halt noch einige Buttons dabei, bei denen ich bisher noch hintergekommen bin wofür die sind. Es tut sich auch nichts, wenn ich die bediene. Muss ich mal nachlesen und nachforschen.
Aktuell interessieren mich die ganzen Cue-Pads. Man sieht viele Videos in letzter Zeit wo Viel mit gearbeitet wird und die DJ's sich die verschiedene Töne auf die ganzen Pads speichern und dann praktisch darüber sich einen Song zusammenstellen und abspielen. Das klappt bei mir bisher nicht. Ich finde einfach nich nicht heraus wie man sich diese Töne abspeichern kann. Wenn ich mir über Cue Töne abspeichere, dann greife ich bzw. das Gerät immer auf das aktuell laufende Lied zu. Ich springe dann praktisch über das Abgespeichert auf bestimmte Stellen im Lied und dann läuft es ab da weiter. Aber das ist ja nicht das Gleiche. In den Videos hört man auch wie bestimmte Beats oder Melodien eines Liedes abgespeichert bzw. abgespielt werden. Aber das geht ja eigentlich gar nicht, da diese Stellen im Lied noch viele andere Töne im Hintergrund beinhalten, die man dann eigentlich hören müsste. Wahrscheinlich arbeiten die mit Stem-Dateien oder so. Keine Ahnung. Irgendetwas mache ich wahrscheinlich noch falsch.
Jedenfalls kann ich mir bisher nicht vorstellen wieso DJ's andere Geräte vorziehen 😃 Super-Gerät. In das Thema Mappings erstellen etc. muss ich auch noch einsteigen. Da kann ich mir aktuell auch noch überhaupt nichts darunter vorstellen wie man das handhabt etc.
Posted Fri 01 May 20 @ 11:43 am
