If I use a different program to create hot cues. Can Virtual DJ 8 can read it, so I don't have to re do it?
Posted Thu 21 Apr 16 @ 1:45 am
Don't you think one would want to know what program created the hot cues?
Posted Thu 21 Apr 16 @ 2:22 am
I really like to use inkey, and inkey now can creates hot cues.
Posted Thu 21 Apr 16 @ 2:32 am
It's probably easiest to try it.
If you set "getCuesFromTags" to Yes, VDJ will get the hot cues from the mp3 file, which works with Serato hot cues.
But I don't know if other software writes the cue points in the same standard way in the mp3
So... A quick test is probably the easiest way to find out
Posted Fri 29 Apr 16 @ 11:58 am
