Hey, I use serato and I have a bar that needs video, so Im using VDJ for this location, can I map a few keys I use like control left/right arrow combo to load the decks 1 or 2.
thanks
thanks
Posted Tue 19 Apr 16 @ 10:52 pm
Sure.
Open config and click on "Controllers" icon on the left
On the top of the page select "Keyboard"
On the bottom click on the "Key learn" box
Press your desired key combo.
If the combo you selected is already assigned to an action you should see it on the "action" box.
You can edit the action or select a new key combo
The actions you need are:
deck 1 load
deck 2 load
deck 1 load
deck 2 load
Posted Tue 19 Apr 16 @ 10:58 pm
Thank you!!
Posted Wed 20 Apr 16 @ 5:53 pm
