In the old version of vdj. You can set the beat skip to 1 button of ur choice in the config page. How would i do that in vdj8.
Posted Thu 31 Mar 16 @ 2:43 pm
Try the beatgrid FX.
Posted Thu 31 Mar 16 @ 2:53 pm
Im aware of that. But i had a different way of doing it in old version. Where i would set the skipbeat value to +1 on right key and-1 on the left. It enabled me to chop ot perfectly. With a hit of a key stroke. But there is no skip beat in the new version?
Posted Thu 31 Mar 16 @ 2:58 pm
It should still be there, check the mapping and look for what button(s) it/they are.
Posted Thu 31 Mar 16 @ 3:05 pm
Yeah i went into config. I searched to find it. I dont see skip beat.. I see repeat and some others bit no skip beat
Posted Thu 31 Mar 16 @ 3:09 pm
Seek+1
Seek-1
Or use "goto +1"
Seek-1
Or use "goto +1"
Posted Thu 31 Mar 16 @ 3:17 pm
Does anyone else have difficultly adding music to their virtual DJ folders? I recently updated to a Mac Book Pro. I am trying to load my music onto Virtual Dj and add songs to my individual folders but for some reason its not saving the songs I'm dragging from my external hard drive.
Posted Thu 31 Mar 16 @ 10:52 pm
What format is your external hdd? Ntfs? exFat? Fat32?
Posted Fri 01 Apr 16 @ 10:41 am
like CHOP AND SCREW with the music SLOW ? if so I tried it with key lock off and it didn't sound like Dj Screw sound.
Posted Mon 04 Apr 16 @ 7:45 pm
