hi guy can you help I cant see what karaoke track ie sf e ect shows a mic but gotta click on it to see what version I used to see along side the song whats happened can you help please alun
Posted Thu 31 Mar 16 @ 1:00 pm
Can someone from the UK please translate this for me?
Posted Sun 03 Apr 16 @ 6:09 pm
Hi. I have ordered my discs into a folder per disc. For example disc "024 sunfly 245". Using VDJ 8 you can add the folders to the search parameters when you search for a song you can state "sunfly" with the song name, only the sunfly karaoke will come up in the search. And/or with the same file system, add the folder path to the search box (where all the details of the search results are). you can then search for the song as normal, then know what version it is by the folder name. and new songs I add I ensure each song as the maker name included.
Posted Sun 03 Apr 16 @ 7:06 pm
