Hay folks, new here. Is there a tutorial on how to (burn)record to Mp3 from virtual dj on a Mac?
Thanks
Thanks
Posted Sun 13 Mar 16 @ 9:16 pm
There's probably something in the wiki but it'll really depend on the setup your using.
Posted Sun 13 Mar 16 @ 9:43 pm
Will this help?
Posted Sun 13 Mar 16 @ 9:45 pm
Yes and no, lol. I have VDJ 7, link was for VDJ8, so I just downloaded 8. I am going to try it out in a few. Thanks
I'll post back and let you know.
Posted Mon 14 Mar 16 @ 4:37 pm
All good after downloading VDJ-8, thanks. I know know how to record.
Are there any Mac users that use a external stereo USB sound card to preview with headphones?
Posted Fri 18 Mar 16 @ 6:14 pm
I use a m-audio m track to record all my mixes directly into garage band or logic pro x on my MBP. I also sometimes use this device to preview with headphones depending on my setup. When I started out DJing I did not have a controller and had to use a smaller USB sound card for previewing and having a separate master output. What are you looking for?
Here is the link to the mike version of the audio interface I currently use:
http://www.amazon.com/gp/product/B00NWE79BY?ie=UTF8&keywords=m%20audio%20m%20track&qid=1458559145&redirect=true&ref_=sr_1_1&sr=8-1
Posted Mon 21 Mar 16 @ 11:23 am
Thanks
Thanks
Posted Tue 05 Jul 16 @ 9:17 pm
Thanks
Thanks
Look for an app called Audio Hijack from Rogue Amoeba Software. I have been using it for nearly 4 years and it works amazingly.
Posted Tue 05 Jul 16 @ 11:26 pm
I have been using using C_Media USB Headphone Set with my 27" iMac it works surprisingly well. I have been using it for 2 year now. Just make sure that you brief yourself with the Audio Midi Setup program and that all output and input runs at 44100.
I bought my at Frys for 10 bucks
Posted Tue 05 Jul 16 @ 11:33 pm
