The title says it all.
more it has strenght level, more the volume goes down.
Is it normal ?
Is it normal ?
Posted Thu 10 Mar 16 @ 3:43 pm
Just a guess ... Are you triggering with velocity sensitive pad or button? If so could be mapped that way.
Posted Thu 10 Mar 16 @ 4:00 pm
Strenth is max 40%
and lenght 3/4 bit, almost never touch it
Posted Thu 10 Mar 16 @ 8:51 pm
Loop Roll Effect doesnt have any Strength Parameter anymore. Unless you are talking about a non-native Effect.
See if there is any Loop Roll.ini file in the Plugins/Sound effects folder or any other Loop Roll.dll file , delete them and re-launch VirtualDJ
Posted Fri 11 Mar 16 @ 12:22 am
well my home editon has it...
its all VDJ default effects.
Left knob is strenght (%) level and right knob is level (bits)
Both working.
unless there has been an update or something..
Both working.
Posted Fri 11 Mar 16 @ 1:02 pm
What build version are you using?
As said above, the built in Loop Roll doesn't have a Strength parameter and hasn't for a long time. It only has one knob and that is for length (in beats).
Posted Fri 11 Mar 16 @ 1:55 pm
I havent updated VDJ since juin 2015...
it says it all..
it says it all..
Posted Fri 11 Mar 16 @ 6:33 pm
yeah the early version of loop roll worked similar to how v7 overloop worked, this caused problems and had to be changed. update or live with it i'm afraid.
Posted Fri 11 Mar 16 @ 7:19 pm
