I am having trouble getting my speakers to play sound. I have a stanton DJC.4 Controller and have my speakers hooked up through the Master Out (Balanced) Outputs via XLR cable. However when I try and play music through Virtual DJ 8 it only plays on my headphones and through my mac's built in output. No sound coming from my speakers whatsoever. Is there a setting I need to change?
Posted Sun 06 Mar 16 @ 11:18 pm
Please look here, and start at page 4. There are also some advance settings there, that you might want to read. Also be aware that you are limited to 10 minutes of controller use at a time, because of your home user status.
Posted Mon 07 Mar 16 @ 10:22 pm
- Make sure the Audio configuration of VirtualDJ is set as shown in the Manual (Master to Chans 1,2 of the DJC4 and Headphones to Chans 3,4 of the DJC4 sound card)
- Make sure the DJC4 is not the default (input/output) sound card of your Mac and properly set to Quadrophonic (4 Speakers) . See here (scroll down to the Mac section of the page)
Posted Wed 09 Mar 16 @ 3:32 am
