i have virtual dj 7 & 8 pro license and i dont see a mapper to this controller in the mapper tab: http://www.kam.co.uk/index.php?action=product&product_id=494
it Says on the site that its working with VDJ7 but i cant find tne mapper, is there a mapper to this controller or it works only with his LE version ?
Posted Sun 06 Mar 16 @ 3:34 pm
From old posts on here, apparently it's detected as Generic ME800 rather than under the Kam name.
Posted Sun 06 Mar 16 @ 3:38 pm
First of all thanks for the reply, I'd love to know for sure that it really should work particularly with the 8...
Posted Sun 06 Mar 16 @ 3:42 pm
have you tried it with pro?
most of the mappers are built into vdj8 now so u don't need a separate mapper file in a lot of cases.
Posted Sun 06 Mar 16 @ 3:43 pm
yse i know, i checked the mapper list and the digi two name wasn't there...
Posted Sun 06 Mar 16 @ 3:48 pm
See the old post here.
The issue with this type of product is that it's mass produced in a far off land and then bought in by the likes of Kam and renamed - but internally (i.e. the ID it shows to the computer) it's not been altered to reflect the rebranding.
Posted Sun 06 Mar 16 @ 3:53 pm
KAM Digi is natively supported in both ver 7 and ver 8, named as Generic ME800. This is the name chosen by the manufacture when we first supported this unit.
Unfortunately manufactures offer the same device in the market under different names.
Posted Mon 07 Mar 16 @ 1:39 pm
