Topic: Hi guys looking some help please
Hi guys just joined, I'm looking for some help, I have always used my 1210s and cdj800 mk1's but I have a lot of music on my computer, I have a behringer ddm4000 and I am wondering if it's possible to use vdj with my cdjs and ddm4000, I must say I am clueless when it comes to the digital side if things so any help would be appreciated, thanks again guys
Posted Mon 22 Feb 16 @ 9:53 pm
Sure can ;)
The gear you mention is all analogue gear - as in not directly built to control a computer.
But with a special computer signal on vinyl or CD (called timecode signal) - you can easily use them to control VirtualDJ.
A little about what timecode is here : https://virtualdj.com/wiki/What%20is%20timecode.html
All you would need to invest in is a soundcard, that at least two stereo in / out so that you can connect analogue sources so that the computer (and VirtaulDJ) can hear the signal from your gear. This way VirtualDJ will instantly react to scratching, pitch changes, play, stop etc etc that you do on your turntables or CD player.
The timecode vinyls you would have to buy. Around 10-15$ ish.
Either the VirtualDJ type https://virtualdj.com/buy/ (bottom of this page) or most other brands are also supported. For example Serato vinyls from local dj store/guitar center etc.
Timecode CD's you can download for free : https://virtualdj.com/products/timecode/cd.html
If you want to 'play' Virtual DJ from your CDJs then the only way to do it (as they have no USB) is to use timecode CDs.
You would then require a suitable audio interface to get the timecode signals from the CDJs into Virtual DJ, and the music out from Virtual DJ to your mixer.
This would require an interface with two stereo inputs and two stereo outputs e.g. MixVibes U-MIX 44.
Haha, Rune beat me to it!
hehe.. all good ;)
Thanks very much guys, would yous recommend any sound cards to buy
See my updated post above for a budget option.
You would also need a timecode license for Virtual DJ ($150) but that would be for home use only.
For pro use you'd need either the monthly subscription license (which allows use of VDJ Pro) or to buy VDJ Pro outright.
Thank you for your help I'll get a look now
A little video for a bit of a guide to how it all works
Thank yous for all your help
dj-in-norway wrote :
Sure can ;)
He won't be able to use VDJ8 and the MIDI functions on the DDM4000, as it is an unsupported device. It can be used with VDJ8 as an analog mixer, however.
You're late to the party. Those posts were made almost a year ago, and it's bad form to bump old threads.
Besides, the post you unnecessarily quoted in full does not mention MIDI control at all, so I don't know why you felt the need to respond.
[shrug]
