I've been knocking my head like crazy trying to record a video, so i started using default record from VDJ8
i chose webm mode, then MP4, video result is hopeless, the FPS is really bad and the image freezes most of the time.
So i installed back my FRAPS software wich used to work really good with VDJ5.
Now, i cant see the yellow numbers (FPS) there is no sign that the software is recording the VDJ video (i set F9 to activate record)
but when i close the program it prompts me that there is a recording, and ask if im sure to close it.
I also believe that my laptop cant handle video recording, but still wondering why FRAPS does not work with VDJ8
This are my specs.
laptop hp g60 550ca, windows 7 home 64
Thanks !
AManandhismusic
thanks a lot for your help and closing the other thread... since many of the members here suggest me to search inside forum answers
i thought it was less complicated to post in an old thread.
i posted there because the guy had the same issues i,m having.
what was the advantage of closing it ? nothing.
This are my specs.
Thanks !
AManandhismusic
Posted Tue 16 Feb 16 @ 12:56 pm
Try Bandicam, its better then FRAPS.
And you never mentioned what processor you have in your laptop.
Posted Tue 16 Feb 16 @ 1:30 pm
2.20 GHz Intel Core2 Duo Processor T6600
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=emr_na-c01936284
Thanks for the suggestion. I finally got it to work..how ? newer version.
my registered version of fraps was 2.9, it does not work with win7, newer version is 3.4 i think. it works good, but ill have to spend 40$ to register it.
i will also try bandicam
Posted Tue 16 Feb 16 @ 2:13 pm
People actually "pay" to use FRAPS ?..
Posted Wed 17 Feb 16 @ 2:54 pm
