Hello, I have Vdj pro 8 and it happens that samples sound by the Master Output and by headphones , both of them at once ... It just happen with all samples. I tried to set everything but it always souns as I described before.
How I can do to samples only heard in the Master output? I have an Akiyama Quark SC
Posted Mon 15 Feb 16 @ 8:00 pm
On the sampler panel, click the round button at the top corner.
You can then select "audio output" as master or a particular channel.
If that doesn't work then your sound configuration may be incorrectly set.
Posted Mon 15 Feb 16 @ 8:03 pm
You have asked this question before and you already have a reply here https://virtualdj.com/forums/207408/General_Discussion/Problems_in_samples.html
There is no direct way at the moment to exclude Sampler Output from Headphones, unless you follow the proposed way in the previously mentioned topic.
Topic locked as duplicate.
Posted Mon 15 Feb 16 @ 8:24 pm
