Greetings. I'm going to set up DVS for the first time this weekend but only have 1 turntable. I'm using the A&E Xone23:C I know I have to change some internal wiring for DVS on that mixer but I'm wondering if there are any special instructions about settings in the software for setting up DVS for both decks using only 1 tt?
Posted Thu 28 Jan 16 @ 11:25 am
No special settings. Setup for DVS just Like you have 2 turntables. Just keep the non DVS deck on "internal" mode. Use the clone deck function (in scratch tab) to switch the current song on the DVS Deck to other deck then crossfade over and load a new track on the DVS deck. Rinse and Repeat.
Posted Thu 28 Jan 16 @ 3:10 pm
That did the trick. Peace.
Posted Sat 30 Jan 16 @ 10:33 pm
Hey there, I changed gear and now I want to re calibrate my time codes. I've tried going to options and restoring factory settings but it still doesn't recalibrate when I got back into time code settings. Can someone please help? Thanks in advance
Posted Fri 16 Dec 16 @ 10:16 pm
