I have connected one xdj to the line in 3 of my sz.
Connected the usb of the sz and xdj to computer.
In the audio config set xdj as channel 3 but it still loading songs to deck 1 and if deck 1 is loaded, it loads deck 2 and stay functional on deck 2.??
What did I do wrong ?
Posted Sat 23 Jan 16 @ 7:34 pm
It's not the audio config that controls this behavior but the mapper
Go to mappers page, select the XDJ on top left and then on the right change deck assignment from automatic to any deck you want (deck 3)
This way XDJ will control only deck 3
PS: With SZ you should not have to change sound settings either.
You could leave all the sound be produced by SZ and use XDJ only as HID controller. This way you wouldn't even need to connect line input cable unless you wish to use XDJ with a USB stick
Posted Sun 24 Jan 16 @ 7:21 pm
This is GREAT!! Working 200% and now the XDJ-700 works (natively) perfect too with the new VDJ update!
Thank you!
Thank you!
Posted Tue 26 Jan 16 @ 8:53 pm
