I'd like to try mapping effects to keyboard keys. Can someone help me? IE: mapping F to Filter, L to Loop Out.
Posted Sat 19 Dec 15 @ 2:46 pm
deck 1 effect_select "filter" & effect_active
this will activate the FX on deck 1
change the fx name in the quotes for a different fx
change the deck number for a different deck
if you want it on master use "deck master"
Posted Sat 19 Dec 15 @ 3:13 pm
Hello I need help..Currently using my NUMARK nv deck... mY crossfader keeps moving back to the middle... any help please!!!!!
Posted Sat 19 Dec 15 @ 6:00 pm
Hijack much?
Posted Sat 19 Dec 15 @ 6:10 pm
