Good evening
I would like someone to help me on vdj8 settings.
When uploading the songs tracks the pitch of not remain (0), but rises only goes down.
And the second thing that happens is: when I press start, to start the part of the song does not start normally, but like I've done beakstart and after a while comes the actual speed,
Can someone tell me what to do in practice?
Thanks
Nick
Thanks
Nick
Posted Wed 09 Dec 15 @ 6:45 pm
Perhaps you would be more comfortable in the Greek forum.
Posted Wed 09 Dec 15 @ 10:16 pm
You may want to check that AutoBPMMatch is turned off in the options.
Posted Thu 10 Dec 15 @ 12:58 am
A little information about your hardware may help as well. Are you using keyboard/mouse to mix, timecode, a controller?
There are other options like pitchresetonload that I have turned off. So, when I load a song, the pitch setting is where I left it on the controller or CDJ
Posted Thu 10 Dec 15 @ 1:00 am
