I have a user button on each deck which toggles beatlock on the opposite deck. This allows me to load a song on deck 1 while deck 2 is playing, prepare my mix, enable the button (which toggles beatlock on deck 2), then press play. I can then adjust the tempo of deck 1, and deck 2 will follow.
What I'd like is a script that's enabled (if possible), so that, when I load a new song on either deck, it toggles beatlock off for both decks. Otherwise, I run the chance of a drastic, immediate tempo change on a live deck if I fail to disable beatlock first.
Any help would be appreciated.
Thanks!
Thanks!
Posted Sat 05 Dec 15 @ 11:14 pm
A repeat start script scanning for loadpluse won't do it as you need to toggle beatlock before loading. How do you load tracks? If via controller I know of a way.
Posted Mon 07 Dec 15 @ 7:28 am
Thanks for the reply! I usually load them via mouse drag & drop.
Posted Thu 10 Dec 15 @ 11:05 pm
script which stop track on deck A when it fades to Deck B and vice versa wether automix is on or not. I use Mix_and_ load_next and mix_now 8000ms & mix_now but track on deck A keeps palying after fade to B.
Posted Fri 11 Dec 15 @ 3:10 am
anybody knows?
Posted Sun 13 Dec 15 @ 10:53 pm
