Forum: VirtualDJ 8.1 Technical Support
Topic: Will not close right..
AsTheDJPRO InfinityMember since 2008
Posted Sun 29 Nov 15 @ 8:15 pm
it must a Mac thing. I tried in my PC (maybe I'm doing ti wrong) but no problems I see.
Posted Sun 29 Nov 15 @ 11:51 pm
Can you please check your keyboard mapper for any <ONINIT> key and what VDJ Script it has associated with ?
Posted Mon 30 Nov 15 @ 7:27 am
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="KEYBOARD" version="801" date="2015-11-26">
<map value="TAB" action="" />
<map value="CTRL+PAGE.DOWN" action="crossfader 0%" />
<map value="CTRL+PAGE.UP" action="crossfader 100%" />
<map value="B" action="search" />
<map value="C" action="crossfader 50%" />
<map value="W" action="deck 1 unload" />
<map value="O" action="deck 2 unload" />
<map value="U" action="" />
<map value="E" action="" />
<map value="R" action="" />
<map value="P" action="deck 2 loaded ? deck 2 play ? deck 2 play_pause : on &amp; deck 2 play" />
<map value="Q" action="deck 1 loaded ? deck 1 play ? deck 1 play_pause : on &amp; deck 1 play" />
<map value="SPACE" action="" />
<map value="1" action="deck 1 hot_cue 1" />
<map value="2" action="deck 1 hot_cue 2" />
<map value="3" action="deck 1 hot_cue 3" />
<map value="4" action="" />
<map value="0" action="deck 2 hot_cue 1" />
<map value="9" action="deck 2 hot_cue 2" />
<map value="8" action="deck 2 hot_cue 3" />
<map value="7" action="custom_button 3" />
<map value="Z" action="deck 1 effect 3 active &amp; deck 1 effect 1 active" />
<map value="M" action="deck 2 effect 3 active &amp; deck 2 effect 1 active" />
<map value="X" action="deck 1 effect 5 active" />
<map value="N" action="deck 2 effect 5 active " />
<map value="]" action="" />
<map value="SHIFT+Z" action="skin_panel &apos;withdecks&apos; ? skin_panel &apos;withnodecks2&apos; on : skin_panel &apos;withdecks&apos; on" />
<map value="SHIFT+S" action="settings" />
<map value="I" action="" />
<map value="A" action="deck 1 effect 3 active " />
<map value="L" action="deck 2 effect 3 active " />
<map value="SHIFT+E" action="" />
<map value="`" action="" />
<map value="\" action="" />
<map value="," action="" />
<map value="." action="" />
<map value="=" action="" />
<map value="-" action="" />
<map value="/" action="" />
<map value="SHIFT+Q" action="" />
<map value="SHIFT+M" action="maximize" />
<map value="SHIFT+P" action="browsed_file_color &quot;Magenta&quot;" />
<map value="&apos;" action="" />
<map value="SHIFT+1" action="deck 1 leftdeck &amp; deck 1 select" />
<map value="SHIFT+2" action="deck 2 leftdeck &amp; deck 2 select" />
<map value="SHIFT+3" action="" />
<map value="SHIFT+4" action="" />
<map value="UP" action="var &apos;$shift&apos; ? browser_scroll -10 : repeat 100ms 500ms &amp; browser_scroll -1" />
<map value="DOWN" action="var &apos;$shift&apos; ? browser_scroll +10 : repeat 100ms 500ms &amp; browser_scroll +1" />
<map value="V" action="" />
<map value="LEFT" action="crossfader -5.5%" />
<map value="RIGHT" action="crossfader +5.5%" />
<map value="S" action="" />
<map value="K" action="" />
<map value="D" action="" />
<map value="J" action="" />
<map value="Y" action="" />
<map value="VKEY_42" action="" />
<map value="F" action="" />
<map value="VKEY_50" action="get cpu" />
<map value="VKEY_63" action="" />
<map value="BACK" action="" />
<map value="T" action="" />
<map value="5" action="deck 1 pitch_reset" />
<map value="6" action="deck 2 pitch_reset" />
<map value="G" action="" />
<map value=";" action="" />
<map value="H" action="" />
<map value="RETURN" action="" />
<map value="VKEY_43" action="Show_splitpanel &apos;sidelist&apos;" />
<map value="ONINIT" action="pitch_range &quot;12&quot;" />
<map value="VKEY_44" action="browsed_file_info" />
<map value="SHIFT+VKEY_44" action="file_info" />
<map value="SHIFT+H" action="skin_panel &apos;withdecks&apos; ? skin_panel &apos;withnodecks2&apos; on : skin_panel &apos;withdecks&apos; on" />
<map value="VKEY_47" action="Show_splitpanel &apos;sideview&apos;" />
<map value="VKEY_41" action="show_splitpanel &apos;folders&apos;" />
<map value="VKEY_39" action="show_splitpanel &apos;info&apos;" />
<map value="VKEY_33" action="" />
<map value="VKEY_30" action="" />
<map value="SHIFT+V" action="skin_panel &apos;withdecks&apos; ? skin_panel &apos;withnodecks2&apos; on : skin_panel &apos;withdecks&apos; on" />
<map value="SHIFT+R" action="browsed_file_color &quot;Red&quot;" />
<map value="SHIFT+W" action="browsed_file_color &quot;White&quot;" />
<map value="SHIFT+B" action="" />
<map value="SHIFT+G" action="browsed_file_color &quot;Green&quot;" />
<map value="SHIFT+C" action="browser_remove" />
<map value="SHIFT+VKEY_33" action="" />
<map value="SHIFT+VKEY_30" action="" />
<map value="SHIFT+L" action="key_lock" />
<map value="SHIFT+O" action="browsed_file_color &quot;orange&quot;" />
<map value="SHIFT+VKEY_24" action="font_size +7%" />
<map value="SHIFT+VKEY_27" action="font_size -7%" />
</mapper>
Posted Mon 30 Nov 15 @ 2:34 pm
does this happen when you change to the default skin?
Posted Mon 30 Nov 15 @ 7:09 pm
The default skin & my main skin work ok with the SX-2 up-plug,I need to ck the mapping in the SX-2 it just started this. Thank you I will let you know what I come up with.
Posted Tue 01 Dec 15 @ 2:53 am
