hey guys I have a Question I have mapped a button that will do loop load prepare it worked fine for a while but now is not working I know is not the mapping issue but when I press the button it just wont trigger im using windows 7 pc vdj8 latest update please help thanks
Posted Fri 20 Nov 15 @ 4:40 pm
What is the exact mapping?
There was an oversight of loop_save with no slot which resulted in loops being saved without a slot, so couldn't be recalled with loop_load. This has been sorted for the next build.
In the interim just add a slot number to your mapping, for example loop_load 1, loop_save 1 etc.
Or use the newer saved_loop command - saved_loop 1 will save a loop in slot 1 if it doesn't exist, or recall it if it does. All from 1 button :)
Unlimited number of slots too :)
Posted Fri 20 Nov 15 @ 5:24 pm
hey what you told me it does work I mapped 2 buttons one for loop saved 1 and the other for loop load 1 but what do I do for the other loops that I have saved on all my songs that were saved with the script loop save I renamed the loop from loop save to loop saved 1 and still will not load using the script loop load 1 I have to resave all loops using the script you told me or is there any work around for this please reply thank you
Posted Fri 20 Nov 15 @ 6:19 pm
hey thank you I have figured out I have to rename all my saved loops to loop saved 1 and assign a slot to them vdj 8 should have assign a slot automatic instead us doing it manually thank you for you help sbdj just one more think how can I map a knob to use you filter effect but the filter needs to be off in the middle just like the default filter from vdj 8 thank you
Posted Fri 20 Nov 15 @ 6:52 pm
