Hello all. How can I echo out deck 1 while bring in deck 2 at the same time. What I would like to do is press deck 2 to come in and make deck 1s echo kick in and stop giving me the echo effect. I would like to be able to do it with 1 button if possible. I use the keyboard to do all my work. Any help would be most appreciated. Thank you.
Posted Sat 31 Oct 15 @ 7:39 pm
Look for locodog user he has the script for this métod of echo
Posted Sun 01 Nov 15 @ 2:35 am
Thanks. Yes I'll give him a shout.
Posted Sun 01 Nov 15 @ 7:52 pm
I'm reading but I don't understand.
Posted Sun 01 Nov 15 @ 7:59 pm
He likes to have pffx bottom!!
Posted Sun 01 Nov 15 @ 9:31 pm
use the loop out effect and use the fader to bring the next song up ( echo out from serato is the same as loop out )
Posted Sun 01 Nov 15 @ 9:53 pm
Set of your slot ( Eff tabs) then use on custom button to do what you Need.....(deck 1 effect 3 active & deck 1 effect 1 active ) { this a custom button mapp to Key and DDj-sx-2 to work together or one at a time
Posted Mon 02 Nov 15 @ 4:56 pm
Hello. sorry for late reply. work mode.
Im sorry but my knowledge on scripts ect is very poor. Thanks for the replies.
I'll try explain.
I want to have deck 2 cued up and ready to mix on beat off course and i want deck 1 to echo out as I press deck 2 coming in. I have gone into the custom buttons but haven't a clue as to what to write to allow this action.
I'll try explain.
Posted Mon 02 Nov 15 @ 7:49 pm
Also where do you write these scripts etc.
Posted Mon 02 Nov 15 @ 7:55 pm
