I bought a new dell vostro with win 7, now no matter what i do in audio config when I change deck 1 and 2 to ASIO it goes back to the internal sound card, i reinstalled the cdj 400 driver 3 times uninstalled the laptop sound card twice it always the same, in my two other laptop its ok I press on the cdj 400 picture and the auto config with the ASIO is ok
This is how it is now:
I dont get the "channels" to be like:
cdj 400 1 L&R
cdj 400 2 L&R
cdj 400 1 L&R
cdj 400 2 L&R
Posted Mon 19 Oct 15 @ 2:53 am
it stays on the cdj 400 pic only if the sound card config is on wasapi if i change it to ASIO it goes back the the internal sound card...
Posted Mon 19 Oct 15 @ 2:58 am
I don't really see the problem, ASIO is selected and I assume it is working as expected?
Posted Mon 19 Oct 15 @ 9:39 am
If you mean the preset buttons on top, don't mind that. They just load presets.
And most likely the "Internal Soundcard" button turns on because Windows are using one of your CDJ's as their default playback device ?
Posted Mon 19 Oct 15 @ 5:02 pm
