Hello all. sorry if this has been covered before couldn't find any precise info on how to rename version 8s backspin. I would like like to use version 7s backspin in version 8 but don't know how to do it or where to begin renaming. Thank you. Tony.
Posted Thu 15 Oct 15 @ 6:10 pm
Backspin is a native effect/action in VirtualDj 8 and it can't be renamed or deleted.
Posted Thu 15 Oct 15 @ 6:38 pm
ok thank you.
Posted Thu 15 Oct 15 @ 6:39 pm
V7's backspin can cause issues with V8 but with a great amount of testing you can learn the nuances and use it problem free.
Find the V7 backspin.dll and rename that to backspin1.dll (it'll be found in my docs vdj folder somewhere)
The problem I found is it doesn't switch off and has a memory of the activated beatpos, which triggers in the next track, remember to turn it off, or as I suspect why you want the v7 effect, double tap (for a slipped effect) then it works fine
Posted Fri 16 Oct 15 @ 6:09 pm
As usual you the man Locodog. Thanks. Try it out after work.
Posted Sat 17 Oct 15 @ 12:40 am
you can always count on Locodog
Posted Sat 17 Oct 15 @ 3:04 am
