What is the best way to downgrade the build? I was trying Beta builds while I did not have any shows. However it seems like there will not be a new Public one before a wedding I have this Friday, that Iwill have enough time to test this week. Should I just swap the exe? Or should I really uninstall the Beta and install an older version?
Swapping the exe was easy and seemed to get what I expected. Just wondering if there are any drawbacks to that approach?
Posted Mon 28 Sep 15 @ 6:26 pm
That's what I do, no problem at all.
Posted Mon 28 Sep 15 @ 7:54 pm
Awesome, seemed the least destructive so I liked it. Thanks for the confirmation!
Posted Mon 28 Sep 15 @ 11:45 pm
