It is easy when your software savvy unfortunately with conditions like Delexia you may as well speak a foreign language. Locodog pointed out your error and then a class example of how it gets misunderstood. Quote locodog '' cue to the skip point, hit remove and drag the right side of the yellow box to the re-entry point, save. But this is also wrong as Locodog did not mention that you have to finalise a remove before the save.
Posted Thu 01 Oct 15 @ 3:22 pm
There is no finalise?
You add a remove section, position it, size it.
You then listen to it, make sure you're happy with it and if you aren't then adjust and repeat.
Then save. Done.
Then save. Done.
Posted Fri 02 Oct 15 @ 8:00 am
Cheers both . Its been an interesting learning curve .
Posted Fri 02 Oct 15 @ 10:01 pm
