Hello all,
I'm currently experiencing difficulties in using the following VDJS command in v8:
set_cue 1 & cue_name 1 "test"
Basically all commands work but "cue_name". It simply does nothing.
The above script will create the cue point but the name stays at the default "Cue 1".
Event if I call cue_name directly (without the chaining) it does nothing.
Is there anything I need to do to get this to work?
I tried calling the command via "SendCommand" from my plugin but even an action POI didn't do the trick.
Any related issues known?
Thanks in advance,
Marco
Update:
okay something is bogus here.. even if I map "set_cue 5 & cue_name" to letter A on my keyboard, it will set the cue point but won't ask for the name (as it should, judging from all the posts here on the forum).
Update 2:
got it working with the keyboard mapping: set_cue 5 & cue_name 5 "works!" does indeed work.
However the same command won't change the name when used anywhere else.. please don't tell me I can only change cue names from mappings?
Thanks in advance,
Marco
Update:
Update 2:
Posted Sun 20 Sep 15 @ 8:37 pm
