Hi folks..Need a script to turn on EQ_LOW_KILL...Not talking eq_reset. That won't Work...This key can only be press once .For instance, I have a key already programmed to activate the Eq_KILL_LOW. That same key when press again will remove the kill action by default. I need a separate key just to remove the kill. We are here to help each other. Thanks .
Posted Sat 19 Sep 15 @ 5:34 pm
eq_kill_low off
This command will ONLY turn off kill (It won't toggle)
Posted Sat 19 Sep 15 @ 5:39 pm
Thanks..It worked.
Posted Sat 19 Sep 15 @ 6:01 pm
