So I just got a vestax vci-300 and a vfx-1 and in virtualdj it says they both fail to connect, cant get them to work in serato either...any suggestions?
Posted Fri 18 Sep 15 @ 4:45 am
PC or Mac? Have you installed the latest drivers and firmware? Different USB cable? Is it possible that the controllers are broken?
Posted Fri 18 Sep 15 @ 6:58 am
Windows detects the devices correctly and can play sounds on windows like a standard soundcard?
Posted Fri 18 Sep 15 @ 9:55 am
so please set the internal soundcard as standart device for windows first and reboot windows.
perhaps some appplications want to use the default audio interface and block access from VirtualDJ ?
Posted Fri 18 Sep 15 @ 11:07 am
