Forum: Old versions
Topic: Pioneer ddj sb2 - Page: 2
Thanks for information! Best regards!
Hi, my SB2 is working, but when I try to set it up so that I can use the headphones, it says that there's no soundcard detected. Anyone know of any reason this might be happening?
If Windows 10 is what you are using, then there may be an issue with the drivers compatibility. Known issue with Pioneer drivers.
Try to re-install the ASIO drivers, make sure the DDJ-SB2 is NOT the default sound card of Windows and try again.
Hi, everyone! When i was installed VD8 and got a license for my ddj sb2 on stacionar PC, i wanted to lunch it on my portable, but program announced, that connection is filed. Does it means, that my license works just on one machine?
You can be logged on to two machines at the same time.
Thanks! I found the problem. That was in usb power configuration. :)
Hi, guys! One more question. What if I haven`t access to internet. Did my license will works on VD?
Thanks a lot! :) Have a nice day!
hi is there any skin that is free for the pioneer ddj sb2 for vdj 8
kithVirtDJ wrote :
I already got a DDJ SB2 and hacked the existing mapping files for the DDJ SB to work with that.
Only two small additions were necessary (for the gain/trim controls and the LED vumeters).
As far as I can tell, works without problems.
I am not sure if/how I can post the files here (if it is allowed at all) , please advise.
Could you send files by e friend I 'm from mexico?
Hi, I'm looking to purchase the Pioneer DDJ SB2 (i'm new to this and in no way a pro - just enjoying learning on this). My current DJ Tech controller has recording capabilities and I wonder if I will still be able to record with the DDJ SB2? More importantly - does VDJ have support for the DDJ SB2 now (it's not listed in some areas of the website). Thank you much.
Hello, support for the DDJ SB2 is built into Virtual DJ 8. If you are using the latest version of Virtual DJ then you can record on your PC within the software. Just pick and destination folder and you should be good to go.
Thanks a lot.
Pls fellow dj's...bail me out...I use to be a very good d.j on vd7 before but after pioneer. ssb2 the whole stuff has been a mess the computer is saying video driver before it work?
Hey guys, I have the DDJ SB2 and it doesnt work with virtual dj. Does anyone know if their will eventually be a plugin for it? Becuz i dont want o have to map everything into virtual dj myself.
Just a reminder, auto mapping only works with the Pro or Subscription version of VDJ 8 it will not work with the home version.
Pioneer DDJ-SB2 is natively supported in VirtualDJ 8 http://www.virtualdj.com/wiki/VirtualDJ8%20Controllers.html
It will not work with previous versions. Download and install VirtualDJ 8 from http://www.virtualdj.com/download/index.html and give it a try (will work for 10 minutes each time you relaunch the software as a demo) and purchase a license if you like the way it works.
I have a Pioneer DDJ-Sb2 I need mappeur I can play with it on Virtual DJ 7.04 is what if someone can give me full version virtual dj 8.1 it was very good I noticed that he mounted on virtual dj 8.1 but they give you up to 10 minutes 24 who can help me and when I have a party I would assume players who have it sent to my mailbox please! EMAIL REMOVED
and thanks in advance!
Please read the information in the message above yours!
The SB2 will not work in VDJ 7. You will need to use VDJ 8.
You can download VDJ yourself. This will be the "full version". All you need to do is purchase a license to unlock the full features.
73%
