Hi everybody
Here is my config
macbook Pro 15'
2,3ghz intel core i7
8 Go 1600 MHZ DDR3
NVIDIA Ge Force GT 650 M 512 Mo
I use VDJ In timecode with a Cdj 2000 nxs and A reloop RP 7000.
I noticed that i have some mirco-freeze,This happens very randomly, It lasts about a microsecond each time And it is very unpleasant.
I use a Rane SL4 and a Serato timecode file I put on a USB stick. This often occurs when using the Nexus Cdj. I thought it was from the USB key so I decided to use the CD Timecoded Serato to compare, But the phenomenon is still present.
With the pitch Quality I tested all three levels 0-1-2 But that does not change anything.
Can i have some help please.
Here is my config
macbook Pro 15'
8 Go 1600 MHZ DDR3
Posted Sat 29 Aug 15 @ 5:28 pm
Can you define what is "micro-freeze" ?
Is a sound drop ? A freeze on the screen of yoru computer ? A freeze on the CDJ2000 control ?
Posted Sun 30 Aug 15 @ 5:26 am
It's a sound drop
Posted Sun 30 Aug 15 @ 6:33 am
Does it happen when using the 2000's in midi mode??
Posted Sun 30 Aug 15 @ 1:47 pm
I have to check because it's been a while since I did not use vdj in midi mode
Posted Sun 30 Aug 15 @ 3:27 pm
i notice that its happen when i use my ddj sp1, when a song loading on a deck and when i hit a button on the SP1
Posted Tue 08 Sep 15 @ 7:14 pm
